Tubular Crossmember: Calling UMI,BMR, etc
Old 02-05-2010, 06:12 PM
Joshiedoom's Avatar
Default Tubular Crossmember: Calling UMI,BMR, etc
Does anybody make a weight delete tubular powercoated 4l60e stock location transmission crossmember?
If so, point me in the right direction because these look a ton better than stock and im sure they sound a few lbs.
Basically a torque arm relocation kit without the bracket for the torque arm.
Old 02-05-2010, 08:36 PM
UMI Performance's Avatar
Hello,
We can do that for you with ease. I don't know how much weight it would save though. If you are interested send me a PM
Thanks!
Ryan
Old 02-06-2010, 12:37 AM
Joshiedoom's Avatar
Pm sent
Old 02-06-2010, 08:07 AM
Originally Posted by Joshiedoom
Pm sent
Replied. Thanks!
Old 02-07-2010, 11:45 PM
01ssreda4's Avatar
I believe Yank sells those as well.....
Old 02-08-2010, 09:55 AM
BMR Tech's Avatar
Seeing as all of those images are of our parts I am sure we can do one for you
Old 02-08-2010, 10:08 AM
Joshiedoom's Avatar
Ive looked and does anyone make a tubular weight delete version that is strong enough for DDing?
Old 02-08-2010, 10:18 AM
BMR Tech's Avatar
You can daily drive on any of those crossmembers no problem
Old 02-08-2010, 10:22 AM
Joshiedoom's Avatar
But there is none for a factory replacement 4l60e, that I can see
Old 02-08-2010, 10:27 AM
BMR Tech's Avatar
I don't have a listing for one (not a lot of people ask for stock replacement) but can do it no problem....
Old 02-08-2010, 10:59 AM
Pilsner's Avatar
Can you make one with a TA reloc for 4L60E? How much?
Old 02-08-2010, 11:20 AM
Depending on the year of the car we offer them for 93-02 with a torque arm mount, as does BMR
93-97- www.umiperformance.com/2210
98-02- www.umiperformance.com/2208
Old 02-08-2010, 03:00 PM
BMR Tech's Avatar
Sure can
They list for $239.95 and are still the one piece tubular construction just larger tubing (1 5/8" x .120 wall DOM) for the extra load of the torque arm.
The different applications can be found on this page HERE
Any other questions please ask
Old 02-08-2010, 03:29 PM
nemss1's Avatar
can PA Racing make one in chromoly? they have none listed either
Old 02-08-2010, 04:10 PM
BMR Tech's Avatar
I can do a Moly one but it's not going to be much lighter at all (1/4# if that)...there is not much tubing used to make the piece...
Quick Reply: Tubular Crossmember: Calling UMI,BMR, etc
