banging noise after subframe con. install?
I'm having the same problems with umi 3 pointers but only on the passenger side it sounds like they are tightened down all the way but as far as I can tell they are.
I seem to remember reading in my UMI 3 pt paperwork (which I can't seem to find anymore) that it was rather important to make sure that the rear control arms were torqued down correctly. If you heard any noise then it was most likely that control arm mount moving, in which case you'd need to torque it down a bit more until you didn't have that problem anymore. As for the weld-on... I'm not sure. I never bought it because if the car was already twisted I had no idea how you'd actually manage to put it in right. That's just what I remember though....
Hope that helps,
Ryan
