Subframe Cradle
Subframe Cradle
anyone have subframe cradle damage? What the engine sits on basically. scrapes and dents from bottoming out? Seems mine has a dent in the passenger side and i guess its pulling my passenger side alignment off. I noticed on other 4th gen fbodys that they usually do have some sort of scar so i was wondering if its common and if other people have fixed or replaced this hella expensive part. thoughts?
Scratch that last question. Looked into spohn k members. They seem great for half the price of a new gm one. anyone have it installed? Does it change anything like feel or alignment?
I believe they are lighter and more "performance" built than the stock unit. You will need an alignment after the install. I think alot of guys have added this to their suspension. Hopefully they will chime in with their input.
Hello
I noticed that you are having issues with your K Member! And I figured I would just throw this out there for you as another suggestion. UMI Performance offer's a few different styles of K Member's both Stock replacement and a Road Race Version (extra bracing). And if you are looking for maximum weight savings. I would suggest a set of upper and lower control arms to save 33lbs off the front and if you went with Chrome Moly it would save you a total of 35.5 lbs. If you have any other questions feel free to ask. And I will be more than glad to help. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...bgc81p7138k8t5
Thanks Again
Brad
Thanks Again
Brad
