DD handling
Old 03-21-2010, 02:20 PM
Shutout's Avatar
Default DD handling
What would I need to purchase to have a good overall handling/ride Daily Driver?
I already have a set of Spohn CM LCA's, Spohn PHR. I want to add a set of Bilstein HD shocks and SFC's. I'm not sure if I should get sway bars and springs. I will not have the car lowered.
Any opinions?
Old 03-21-2010, 02:36 PM
bigj2717's Avatar
IMO sway bars, shocks, and springs are the three things that will affect the handling the most
Old 03-21-2010, 02:56 PM
Shutout's Avatar
I agree, but which one's to buy?
My car will not be on the drag strip, but I enjoy going through the curves.
Old 03-21-2010, 02:59 PM
Lopoetve's Avatar
Strano for all the parts you can, or so everyone here agrees.
Old 03-21-2010, 03:00 PM
bigj2717's Avatar
You can talk to Sam Strano. Tell him whats done to the car your goals and your budget and he can help you pick out what you need
Old 03-21-2010, 03:25 PM
Shutout's Avatar
Thanks for the advice!
Old 03-21-2010, 06:24 PM
therealcreeper's Avatar
35/21 or 35/22 swaybars. strano has a nice set of hollow bars but if they're out of your budget the UMI solid ones are a great bargain. bilsteins will work well with stock springs.
on a side note i daily drive my car. lowered with lt's and sfc's and hardly ever scrape. my front springs are more than twice as stiff as stock (600#). ride quality isn't bad at all. you can get a car with stock springs to handle very well but springs are a nice upgrade too. not sure why you don't want to lower but it's not bad at all if the roads around you are okay. just thought i'd point that out.
Old 03-21-2010, 07:41 PM
Shutout's Avatar
When I bought the car it had a Eibach pro kit springs on it. I didn't like it. My car scraped on everything.Very annoying.
Old 03-21-2010, 07:44 PM
Shutout's Avatar
Price isn't to much of a problem, as long as I get what I want. No need to spend money unwisely.
Old 03-21-2010, 08:06 PM
99FormulaM6r's Avatar
Shocks/sways with stock springs can give you a good ride and corner well. Either Koni's/Bilstein's for shocks should suit you well, and Strano/UMI sways also. You'll have a tighter ride, even with stock shocks, but less harsh and will corner a lot better.
Old 03-22-2010, 07:26 AM
UMI Sales's Avatar
Thanks for suggestion UMI Performance! Like mentioned above if you are looking to improve your handling. UMI Performance offers both front and rear solid sway bars. Our fronts features a 35mm chrome moly and the rear is a 22mm. And everything is included for the installation process. Below is a link to show you what I am explaining
http://www.umiperformance.com/catalo...bgnigbbebtecf7
If you have any other questions feel free to ask.
Thanks
Brad
Old 03-22-2010, 04:39 PM
Shutout's Avatar
Exactly what I'm looking for!
Old 03-22-2010, 06:35 PM
coolformula's Avatar
1. Konis'
2. Sams hollow bars
3. Set back and enjoy
Old 03-25-2010, 11:08 AM
Sicko's Avatar
Some LCAs and LCA Relocation brackets wouldn't hurt either.
Old 03-25-2010, 11:44 AM
It looks like he already has LCA's, and RB's aren't really necessary unless he's having traction problems, which doesn't seem to be a problem being he's not drag racing and they actually hinder cornering a bit.
IMO, if you lower your car, RB's can be helpful if you are experiencing wheel hop, if not, it's not really necessary.
Old 03-25-2010, 06:40 PM
Shutout's Avatar
I'm never going to lower the car. It was lowered when I bought it and it scraped on everything. I do not have any problems with wheel-hop.When I nail it I do have a problem with traction. I'm hoping the LCA's and PHR will help with that.
Old 03-25-2010, 08:13 PM
ThumperNC24's Avatar
Get Koni Shocks and Sam's Hollow bars
if you want you can lower the car ~.75" with just the shocks and hose mod. It will look a little better and you won't scrape on everything.
BTW, the LS1 Pro kit springs you had were probably really sagging (they have horrible quality problems) and that is why you probably had so much trouble with them.
Quick Reply: DD handling
