help , caliper rebuild kits neeeded
Old 05-06-2010, 07:11 PM
foxz's Avatar
Default help , caliper rebuild kits neeeded
doers any one know the part numbers for rebuild kits for a 98 camaro front and rear calipers, i cant find any local so will need to go online. i was going to just buy new ones but im getting them powdercoated and what not so need to rebuild them. thanks
Old 05-06-2010, 07:13 PM
Tudds's Avatar
I was just going to make this thread!!!!!!
http://www.rockauto.com/catalog/moreinfo.php?pk=1301983
I found these 6 bucks, I'm only rebuilding my rears and want to know if the pistons are the same as the front/rear.
Powdercoating as well.. my fronts are brand new so I'll reuse those seals
Old 05-06-2010, 07:14 PM
Tudds's Avatar
2002 CHEVROLET CAMARO SS 5.7L 350cid V8 FI (G) OHV : Brake/Wheel Hub : Caliper Repair Kit Price Core Total Advice
DORMAN Part # D670013 More Info {First Stop}
Rear; Bore = 45.5mm; Axle Kit
Front; Bore = 45.5mm; Rear Disc Brakes
* Non-stock item--shipping delayed up to 2 business days
Old 05-09-2010, 12:15 PM
foxz's Avatar
anyonme?
Old 05-10-2010, 12:11 PM
FBDYLVR's Avatar
Don't know what else you're asking for. I just bought the same kit from rockauto. There's 2 seals per kit, so you would need 3 for the entire car (2 pistons per front caliper, 1 per rear)
Old 05-10-2010, 12:39 PM
foxz's Avatar
so the rears come with two aswell so its a set for the rear and one each for the front? makes ita bit better
Old 03-04-2013, 02:03 PM
Jeff Smith's Avatar
Thanks. I found this information helps. I need order some boots..
Quick Reply: help , caliper rebuild kits neeeded
