Do I NEED an ajustable torque arm? car came with non adjustable.
Well when I bought the car it came with a non ajustable TA whick he said was an old LG peice, it is lowered with the pro-kit, has LCA relocation brackets, BMR LCA, BMR PHB, LG sway bars, bilsteins, BMR SFC's, BMR K-member, BMR upper & lower A-Arms, Should I buy the ajustable torque arm? is it needed? the car seems to drive nice and solid but dont know if will benefit from the new torque arm. IM CONFUSED!!!!!!
Hello
Seeing how you have a non adjustable torque arm. And you have lowering springs. It is hard to say if your pinion angle is going to be -2. For example when we manufactured our non adjustable torque arm. We designed it with -2 degrees built into it at (stock ride height). But if you are looking to fine tune the rear end, I would highly suggest going with a adjustable torque arm to allow you to adjust the pinion angle for best results. But like I mentioned above it is going to be hard to say what the angle is going to be without checking it... and if you aren't getting any vibrations I would say you are ok. If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
hey guys i had the same quuestion...my car is lowered about 2inches in the front and about 3/4 of an inch in the rear (spring isolator mod with stock springs). do i need an adjustable one? this is a street car but i want to get some traction too
