Question about strut rattling - need help
I had a noise in the front passengers side wheel area that seemed to be my passenger side strut. when i opened the hood and pushed down on the battery to rock the car i could hear the shock rattling and it sounded like it was hitting the top of the wheel well.
I replaced the shocks with new Monroes this weekend and the sound is still there. When I push on the car and get it rocking I can hear the shock hitting the top of the wheel well. When i took off my old shocks, I noticed the passengers side shock didn't have the boot that slides over the strut shaft, the strut mount had the metal piece that sits under the nut on top of the strut mount and the strut mount itself didn't look broken down or anything.
could the boot that's missing be the cause of the clunking noise? What is the name of that part and where can i get one?
The shaft on the strut I took off had had stripped threads and the threads in the nut were stripped, otherwise the shock was still in good condition.
I found this picture that shows the boot, the second pic is a pic of the shock mount that I took off.
Finally fixed the noise after replacing ball joints , tie rods and shocks, it turned out to be the upper strut mount, it looked good , but if you looked really close at the rubber around the strut shaft at the top you could see the rubber was splitting when you pushed on it and allowing the strut shaft to rise up and hit the top of the well.
