car wont stay aligned
Location: boaring place where theres more cows than people
ill take my car to get aligned itll stay aligned for a week or two then its out again does anyone have any ideas/ sugestions
are all of ur suspension parts and steering componenets in proper shape and it may be the ppl doin ur alignment. Try a different shop...u can tweek an alignment machine to show proper numbers just to plz the customer.
ive replaced everything except my inner tie rods. and i used to work at this place and i stand there and watch to make sure everything is done correct
im a certified tech for nissan and its usually a suspension or steering component ...i have had in the past tire issues ..broken belts......or if the person performing teh alignment does not jounce "bounce" the vehicle the tie rods do not return to center and the result can be a couple tenths of a deree off therefore resulting in a mis alignment ....wat is not staying aligned....another thing i have seen is rack bushings bad.......hope this helps
