Horrible squealing from rear end....
Old 07-08-2010, 04:05 PM
arioch's Avatar
Default Horrible squealing from rear end....
when i go up an incline going slightly left or right, like into most steep driveways....
What you guys think? need new shocks?
Old 07-09-2010, 02:51 AM
arioch's Avatar
anyone? just want to know what to replace here
Old 07-09-2010, 04:03 PM
gbpxl's Avatar
not sure. I'm getting groaning from the rear end but it's only when I turn slowly
F-bodies are notorious for having shitty rear ends. I'd start with that
Old 07-09-2010, 04:56 PM
arioch's Avatar
well im definitly thinking its suspension related as it only happens when i hit funny uphill angles, just dont know where to start
Old 07-09-2010, 10:36 PM
johnpate01's Avatar
Are your rear tires rubbing on the frame rails or inner wheel well sheeting? Mine has done that before if I hit my driveway wrong. Look for shiny spots.
Old 07-12-2010, 12:00 AM
arioch's Avatar
Its not that, my tires do rub in certain situations and i know that sound. its rub the tires since i bought it, this is a new development and sounds like something grinding or failing in the suspension only when i go up angles uphill. anyone else got an idea?
Old 07-12-2010, 09:58 AM
96blackz28's Avatar
What rear suspension mods you got? I know about every sound from the rear.. lol
Old 07-14-2010, 09:44 AM
Greggy's Avatar
Probably the lca rubber bushings if you have the orignals. The rubber seperates and groans. Use moog replacements. They are better than oem.
Old 07-14-2010, 05:31 PM
arioch's Avatar
Completely stock in the rear suspension, SFC's are the only suspension mods on the car.
I have new LCA's with relocation brackets going in next week, think that will solve the problem?
Old 07-15-2010, 07:58 AM
UMI Sales's Avatar
Hello
Like mentioned above it sounds like it is your rear LCA's bushings that are shot (the rubber will break down and the hardware will flex all around) or the hardware itself could need replaced as well. I am sure once you install the new suspension parts and they are properly maintained with grease you will not have any issues. If you have any other questions feel free to ask.
Thanks
Brad
Old 03-25-2014, 02:15 AM
nonnez's Avatar
Default Also require help
Guys I am running a 94 LT1 (71,000 miles) and have the same squeal from the rear when taking a tight corner although right is worse than left at present.
Gear oil and additive changed which has not helps and I have checked the roundels (rear discs and can not see that these have touched the callipers.
Would it still be the C clips or is there anything else I can try.
Thanks Maria
Quick Reply: Horrible squealing from rear end....
