Polyurethane torque arm bushing ?
Old 07-25-2010, 08:46 AM
monzter's Avatar
Default Polyurethane torque arm bushing ?
Hello guys I'we got '93 Z/28 that has got bad bushing in the torque arm !
I was wondering how to choose a Polyurethane bushing for my torque arm, since i'm only running the stock torque arm. What do you reccomend for my stock arm... This car is A4.
And can i change the bushings alone or do i need to get new brackets also ?
How do i remove them old bushings from their brackets ?
I'we got polyurethane bushings in the LCA's, engine mounts and tranny mount, Would it also be a good idea to put poly... mounts in the side bar on the rear ?
Best regards.
Old 07-25-2010, 08:58 AM
SparkyJJO's Avatar
I have an energy suspension poly bushing on my stock torque arm. Like you, the stock rubber one went bad.
It uses the stock brackets, just need to grind the rivets off that hold the old bushing in. The new one will then just clamp in.
Old 07-25-2010, 01:18 PM
96blackz28's Avatar
^^ exactly, go with the energy suspension piece, it is the cheapest one at around $12 and it is a quality piece. Just installed one yesterday and it definitly firmed things up.
Old 07-26-2010, 10:42 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Both Energy Suspension and Prothane make polyurethane replacement bushings for the torque arm. The install is much simpler on the automatic than the manual. You just need some basic hand tools and a grinder as Sparky mentioned above. Just follow our torque arm instructions if you need bolt sizes and pictures of the bushing replacement. You can view them HERE.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 07-26-2010, 05:27 PM
buddha845's Avatar
oooooorrrr you could just replace the whole thing
Old 07-27-2010, 09:40 AM
BMR Tech2's Avatar
True...
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: Polyurethane torque arm bushing ?
