85k miles - worth replacing master cylinder?
Getting ready to do a complete overhaul on my brakes (rotors, pads, braided lines, and fluid) and I was thinking about putting a new master cylinder in at the same time. The brakes have been getting slowly progressively softer (although I am still on the stock brake fluid - I know, it should have been changed already), and I'm sure replacing the fluid, lines, and rotors/pads is going to help that a lot, but I'm not sure what sort of wear parts are inside of the master, aside from seals, and as I'm going to be flushing the whole system anyway, I might as well replace the master now if it needs it.
As far as replacement part quality goes, any difference between Centric and AC Delco non-reman?
