Bad shaking when braking
I know enough to figure stuff like this out, but I'm at a blank and need some ideas on what to check.
I just installed a C5 vette package on my car. An aftermarket bracket, C5 calipers from a 50th anny Vette, EBC green stuff pads and some ridiculously beefy drilled/slotted rotors.
So now after they've been broken in, when I'm braking between ~40-30mph I get a really bad shaking. I can feel it coming from the front. I took my rims off and checked everything out and everything seems tight and snug. And with the size and thickness of the rotors I'm sure I can safely say I didn't warp them. And visually they look fine.
Anyone have any ideas on what else it could be? Could going to a larger rotor thrown off the balance of the tire somehow?
and what break in procedure did you use? if the pads aren't bedded properly they'll vibrate a bit. when I did new pads the car vibrated when braking from above 35 for a few weeks, then I autox'd it and it went away. maybe you just need to do some more braking. I would only advise hard braking if it's a mild pulsating feel. I could tell it wasn't badly warped rotors otherwise I would not have autox'd it like that.
I bought the rotors barely used and had them turned, so I know I didn't install them warped lol I went by EBCs instructions, go to 40mph and come to a stop a couple times, then took it easy on them for the first couple hundred miles. They've been on for ~2000 miles give or take and this just started maybe ~1000 ago? I have no clue, I DD my car so I dont watch the miles too well. The rotor is still perfectly smooth in every direction so I don't think the pads didn't bed right. Maybe it is a weight came off? I'll bring my car to a friends shop and have him balance them.
ten year old thread but on topic..
The things I check are:
rotor run-out, radial and lateral..
tie rod ends
ball joints
Wheel runout
I've had more than one set of tires cause horrible vibration even when properly balanced.. Just poor manufacturing.. and even good tires get fouled up.
are the wheels hub-centric? if the lugs are worn the wheel can be off center and it acts up under braking. (Honda's do this if you forget the wheel centering rings... )
You can also get a situation where there are spots on the rotor where the pads didn't deposit the film they should during break-in, so there are varying levels of "grip" between the pad and rotor, a light brush with sandpaper on the pads and rotors then re-execute the break in sequence from the pad vendor.
tie rod ends
ball joints
Wheel runout
