Spohn Adj. TA
Spohn Adj. TA
I had a shop set my pinion angle while they did the alignment . They left a nut loose that caused the upper rod end to snap .
Got the part , heres the question : The nut on the top rod end tightens against the torque arm ? The directions make it sound like it tightens against the bracket to hold the rod end from moving .
