Torque arm keeps coming loose...any ideas?
Old 08-22-2010, 12:37 AM
camaroboricua's Avatar
Default Torque arm keeps coming loose...any ideas?
Ok, so im not pitting down a ton of power but I do drive it hard but why does my torque arm keep coming loose? I have to retighten it about once a month, and I only drive it on weekends. The old one I removed was broken so I figured that was part of the reason, so I got a used freebie from a 2000 car and its the same problem. I put new lock washers on it also.
I was thinking that maybe if my transmissiom mount is weak its creating too much movement and causing it to loosen up. Any ideas??
Old 08-22-2010, 12:48 AM
stunna p's Avatar
use some blue thread lock....
Old 08-22-2010, 12:49 AM
AxisOfOil's Avatar
I remember hearing someone else was having this problem. I think they switched to a crossmember mounted ta instead to fix the problem.
I don't have a real idea of what would cause that, but I do know an easy fix. Loctite.
Old 08-22-2010, 09:40 AM
UMI Performance's Avatar
Is this a factory rear end? If so try locktite like mentioned, also a nylon lock nut might work better than lock washers, we always use lock washers and never have an issue.
Old 08-22-2010, 01:07 PM
yes its a factory rear. Im going to try new washers and some loctite. Also going to clean the bolts real good with a wire brush. Hopefully this will fix the problem. Thanks for the advice.
Old 08-22-2010, 02:45 PM
sjsingle1's Avatar
LS1Tech 10 Year
safety wire it !!!!
Old 08-23-2010, 02:20 AM
LilJayV10's Avatar
LS1Tech 10 Year
If its the two long bolts on the rear I'd say the pinch nuts have lost their pinch. Red loctite it and be done with it.
Old 08-23-2010, 10:08 AM
BMR Tech's Avatar
Would have to agree with it sounds like the factory lock nuts are shot... try a fresh set of nylon lock nuts or lock washers
Old 08-23-2010, 08:55 PM
Ill change the nuts out aswell then. thanks
Old 08-23-2010, 09:57 PM
HoLLo's Avatar
Get some sort of degreaser/brake cleaner on the bolts too to clean off all the rear-end fluid that more than likely is leaking since you drive an f-body. along with the previous recommendations.. I just found mine loose not long before it broke at the rear, I'm making sure I get the new bolts/nuts from UMI with my new torque arm soon..
Quick Reply: Torque arm keeps coming loose...any ideas?
