front brake cooling tubes, worth it? on a street car?
Old 08-28-2010, 10:47 PM
stunna p's Avatar
Default front brake cooling tubes, worth it? on a street car?
i have a 02 ws6, below the blinkers on the front clip there is an empty hole on each side. im debating making some cooling vents to cool the front brakes. i have stock cheap brakes and rotors. and they shake like a **** after a couple hwy runs. do u guys think this type of home made cooling tubes mounted very close to the front rotors will yield any improvements?
thoughts.................. thanks stunna
Old 08-28-2010, 11:23 PM
ninetres's Avatar
Won't help shaking. It will only aid in postponing brake fade if you are doing some consistent serious braking.
Old 08-29-2010, 06:33 AM
EchoMirage's Avatar
worthless on a street car. you never get to a temperature high enough to warrant brake ducts. if you are, youre doing something wrong. the shaking is a warped rotor, or stuck slide pin. also, the holes below the blinkers are nowhere near a good location for brake ducts, regardless.
Old 08-29-2010, 09:27 AM
SuperSport01's Avatar
Better rotors, pads, lines, and fluid would do alot more for you than brake ducts.
Old 08-29-2010, 05:21 PM
meine96ws6's Avatar
If the car is shaking hard during braking.. I would get it checked.. Could be an indication of a more serious problem..
