Ok if Spohn rear sway touches QA1's and brackets?
Am I hurting anything? Everything feels fine. No clunks.
How much am I taking away from handling with the improper geometry?
I'm going to have to shorten the endlink bolts and barrels...
Thanks, Guys.
The other side is identical. I had to rotate the shocks as well. The stock bar doesn't have this problem at all. When I get the shorter endlinks on, I might get some clearance from the shocks. It's a 22mm solid, I think. It's almost like Spohn's jig was f'd up when they did mine, or the Moser's brackets are off a little.
