Whats Torque Spec for nut on front strut assembly?
Going to start looking installing my brand new koni's tonight.
Just want to get that torque spec and getting everything done right the first time.
Did a pretty heavy search and checked around but couldn't find it!
Thanks Rob
Thanks Rob
Well, since you are doing the whole job...
Hope this helps :
Shock Absorber Lower Bolt - 65N-m / 48lb ft
Shock Absorber Lower Nut - 65N-m / 48lb ft
Shock Absorber Upper Mount Bolt - 50N-m / 37lb ft
Shock Absorber Upper Mount Nut - 43N-m / 32lb ft
Hope this helps :
Sorry should of been more exact with question.
The nut you need to take off and install with while using the spring compressor to remove pressure on the nut on top.
