Brand new QA1's seem to be junk already...need help!
Just purchased these from a member on here. Brand new in packages still, 12 way single adjustable rears. I just install these about 2hrs ago, took it out for a spin on the lowest setting just to see how it felt. I got out and went to turn the setting up to make it more firm. One of the shocks adjusted just fine but the other wouldn't. The **** would absolutely not turn up or down. There was also a little "play" in the **** and the other side there was no "play"
Has anyone experienced this? Does this shock need sent back to QA1 already!? The ***** on both of the shocks turned just fine before i even installed them...
I called QA1 and they said that the shock may need to be sent in for them to look at it. They also said that sometimes when you're turning the **** that you don't know if there is another click or not, so you try to turn it one more time and it'll get stuck since it won't turn any farther. I pulled the shock off and the **** just needed broke lose. It works fine now...silly me.
