Setting Pinion angle from pros that know how to tune suspension PLEASE!
Old 10-21-2010, 11:37 PM
94BlueZ28's Avatar
Default Setting Pinion angle from pros that know how to tune suspension PLEASE!
I'm getting 1.66 60ft's but I know I could do a little better. My whole rear is supported by BMR and it's all adjutable. I've found the sweet spot running 15 psi in my mickey thompson's. I'm wondering where I could adjust to get it to hook a little better. I'm set pretty much at stock settings with the panhard, control arms and -2 degree's on the Tq arm. I was wondering if I should adjust the torque arm but really dont know which way to go. Any advice on where i should set it. Thanks for the advice.
Old 10-24-2010, 02:20 PM
leadfoot4's Avatar
From everything I've heard, (-)2 to (-)3 degrees is where you should be...
Old 10-26-2010, 02:19 AM
HoLLo's Avatar
Do you have LCA relocation brackets? I know -4 on the torque arm can be a little bit more for drag racing, but puts too much wear on the rear if street driven often
