Torque Arm
Old 03-22-2011, 02:26 PM
nick2334's Avatar
Default Torque Arm
I am looking into buying a new torque arm what would you suggest looking into getting?
Old 03-22-2011, 02:57 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Depends on what kind of driving/racing you are going to be doing with the car. Also whether your car is lowered or will be in the future. Tell us a little more about the car and your plans.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 03-22-2011, 03:08 PM
nick2334's Avatar
I am keeping a street/ strip car probably will never lower the car. Eventually i would like it to only be a strip car.
Old 03-22-2011, 03:26 PM
BMR Sales2's Avatar
The ideal setup for a street/strip car would be a BMR full length adjustable torque arm used together with a BMR torque arm relocation transmission crossmember. The adjustable torque arm will allow you to adjust pinion angle and the crossmember will allow you to get the torque arm off the transmission and will allow you to adjust instant center. This setup has been proven to work will on the street and has been solid single digits in the quarter mile. Here are some quick pictures of the parts.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 03-22-2011, 07:35 PM
01ssreda4's Avatar
Id get a full length adjustable with the trans relocation cross-member from UMI or BMR.
Old 04-08-2011, 07:46 AM
blkside's Avatar
What if you were lowering the car 1.25 - 1.50 inches?
Old 04-08-2011, 08:03 AM
BMR Sales2's Avatar
If you are going to lower your car you are definitely going to need an adjustable torque because lowering the car will throw off the pinion angle. I would recommend using BMR part number TA001 which comes in red or the black hammertone and is adjustable to allow you to get the pinion angle back were it needs to be.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 04-08-2011, 09:23 AM
NC98Z's Avatar
Spohn make a very good setup also. I am very happy with mine. Speedinc. has free shipping on orders over $100 right now. I just took advantage of it.
Old 04-08-2011, 01:42 PM
SOMbitch's Avatar
You'll need a new mount with the TA relo kit. Pretty cheap for a polly one....
Old 04-08-2011, 02:17 PM
BMR Sales2's Avatar
You can use any of the after market torque arms with the BMR torque arm relocation kits, if you want to use your stock torque than you will need to purchase a Prothane or Energy factory torque arm replacement mount.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 04-13-2011, 10:33 PM
mynameisray's Avatar
I was wondering the same thing, my car is lowered on eibachs and its pretty low truthfully and was pondering over a torque arm as well. Gonne throw some 4.10's and nitto triple nickels on it as well. Figured the torque arm would top it all off...
Quick Reply: Torque Arm
