why is my car shaking??
Ok so I have a 99z and just got lowered,put new shocks and panhard bar so the shop I took it to told me I didn't need an alinement car drives straight doesn't pull but on my home I noticed the car shaking as I accelrated more noticeable after 60-70 mph does anyone know why this is happening I also just swapped rims so I took them to get balanced and it helped quite a bit on them shaking. Wht do u think it is or should do
I'm assuming this isn't making the steering wheel shimmy therefore I'll say this: Often after lowering the car your pinion angle will be off unless you have an adjustable torque arm. The tail of the transmission doesn't move, but now your rear is tucked higher in the car so the angle of the driveshaft in relation to the two isn't the same anymore. The angle on both sides of the driveshaft need to cancel out each other because u-joints don't spin at a constant speed. I had this problem in my old car.
I'm curious with this also. After a trip to Charlotte. My front right wheel would start to have a wobble feel.to it. Some what vibrate. I have to get my lug nuts cracked so I can do my brakes. I'm tossing it.up to a possible warped rotor. But I'm open to ideas.
The only way I know of to adjust the pinion angle is an adjustable torque arm assuming this truly is your problem. Does your steering wheel shimmy much or does the shaking more pronounced near the shifter?
It's an auto but the wheel was moving alot more before I got the tires balanced again but it does still move alittle but it feels like the whole car moves not only the front
"and just got lowered,"this would totaly change the alignment so you Need alignment, if the alignment is off a lot you would be draging/scuffing the tire side ways, THIS may cause your ptoblem
"Often after lowering the car your pinion angle will be off" if angle is off THIS may cause your problem
"and panhard bar " is this adjustably? you may need to center the rear under car, do not think this would cause your problem
Johnny
Johnny
Typical "toe and go" shop......Don't EVER go back there, if you want your car done right.
Any ideas on why my front right tire would wobble? Besides being off balance. I drove over really shitty roads in Charlotte. After that. Is when it started. Sorry I don't mean to hijack.
Johnny
Johnny
Yes they were used I got the the front tires balanced they were off after Balancing it got a little better so I'm going to get it aligned today and c if it helps
This shop is pretty legit I think they make parts for camaros and mustangs they told me it's didn't need to b aligned cuz it drove straight but I haven't talked to them about the shaking they were closed wen I was going home
Ok so I talked to the guys from the shop and they told me it could b the pion is off but highly unlikely since it wasn't a drastic drop I lowered my car bout an 1" 1/2 and they told me it could either b the tires or the tire spacers I have in the rear I had tires spaces for my c5zs and they still on there after the rim swap so they offered to take em off for me and c wht happens can spacers cause vibration?
For example, the toe can be OK, the caster be OK, but the camber be 2* positive...which is NOT OK, but the car will drive pretty straight. Or, the camber can be OK, the caster be OK, but each wheel "toed-out" 1/4", which is NOT OK, but again, the car will go reasonably straight. In both examples, the car WON'T handle correctly, but it will go reasonably straight, so THAT ALONE, doesn't define proper alignment....
Interesting. Is this something a Watts Link helps address as well?
No. A watts link really won't affect the pinion angle.
I wouldn't call 1-1/2" drop *drastic* but it is significant. Wheel spacers *could* be your problem, but I get the impression you had these spacers on before the shaking problem occurred. Of course it's easy to remove them and see what happens.
So I'm thinking the problem is coming from the rear I'm not getting any steering wheel shake and it seems it's coming from the rear since the front doesn't really shake Anyone??
