Shocks loose on install
So I am changing out the shocks an spring on my 99 an I got the shocks back in but there loose a at the top in the hatch the self locking nuts won't fighting down any further so the wobble side to side like 1/8 of an ochre I have the axle lowered down to put springs in still so input would be nice
front is a little bit longer process but by no means hard. Just make sure that when you get the shock/spring assembly back together you compress the spring enough so that there is no play in the upper mount. In other words tighten the top nut or you will get the clunking sound when you go over your first bump.
