New Bilsteins/Stock front springs/ NEED INSTALL INFO
Old 03-09-2012, 07:18 PM
428 78T/A's Avatar
Default New Bilsteins/Stock front springs/ NEED INSTALL INFO
Somebody help me out and point me to some good info regarding New bilsteins with stock front springs/ INSTALL PROCESS.
Already did the back, that was easy.
Yeah, dont' tell me to search. Search is broke with 99 thousand bits and pieces of info.
99 Trans Am
Old 03-09-2012, 07:46 PM
pewter2002's Avatar
TheBlueNight has a home made video that he made with pretty complete instructions. I searched Koni video install on this site and it was the first hit.
Old 03-09-2012, 08:55 PM
ssbone's Avatar
Indeed, I used TheBlueKnight video as reference, got them on no problem, however I have a rattle in the front end now I'm trying to figure out.
I did have to replace the sway bar links, mine were rusted and broke when I tried to loosen them. Just a heads up!
Old 03-09-2012, 10:07 PM
428 78T/A's Avatar
Thanks fellas. Just didn't want to dissasembel that top castle nut till I had some confidence thats how it should be disected first lol. Cool.
Old 03-10-2012, 07:17 AM
bigbomber5's Avatar
*off topic* to OP
Next time you want to do a search, go to google and add ls1tech after your topic
Old 03-10-2012, 07:59 AM
z28bryan's Avatar
http://www.ls1howto.com/
Old 03-10-2012, 08:10 AM
bayer-z28's Avatar
OP: Google search actually works better than the forum search. just type in your topic and add LS1tech.com at the end...
But anyway.. I did a install thing back in the day. -About 1/2 way down.
http://www.cardomain.com/ride/463707...-camaro/page-2
Old 03-14-2012, 11:09 AM
428 78T/A's Avatar
Ok, I know I saw it somewhere, now I cant find it
What are the torque specs for the upper control arm castle nut, the 4 top shock mount bolts and nuts, and the two lower shock bolts? I do recall the sway bar being 17 lbs.
Quick Reply: New Bilsteins/Stock front springs/ NEED INSTALL INFO
