Spohn t/a install and moser 9" nightmare PLEASE HELP
I tried to install my spohn adj torque arm on my moser 9 today. I am having the worst time with this. My t/a has the dual hole mounting bracket. I can not get the bolt to go through the holes on the inside, but on the outter holes I can get one bolt fully through and the other through the top but not them bottom. Its like I dont have any room to adjust the arm to allow the bolt through. Anyone have any ideas or tips to finish the install. Also, will a lakewood d/s loop fit with this torque arm?
yes if your standing behind the car looking at the rear you should be using the holes closest to the passanger side, you may have the grind down the bracket on the corners a bit, i had to with my umi mount
Yes, it is with the rear end hanging, which should theoretically let the drive shaft down, its hitting at the top as is. If I let it down, definitely gonna hit.
The car has an Energy Suspension poly trans mount I believe.
