Anyone running Electric Vac Pump for Brakes?
Old 04-09-2012, 03:29 PM
DAVE00's Avatar
Default Anyone running Electric Vac Pump for Brakes?
Looking to install an electric vac pump to help with my brakes due to weak vacuum of this cam (12" at idle). Let me know what you're running and how you like it? Also, where you installed it and the amount of noise I'm looking at? Thanks and any advise is welcome.
Old 04-09-2012, 04:23 PM
ZexGX's Avatar
Pretty sure using a hydroboost system is the answer to this problem, not jury-rigging a vacuum pump. If that thing ever fails mid-braking, your brakes lose most of their effectiveness. Definitely look into my suggestion. Here's an example of a popular kit:
http://www.hydratechbraking.com/GM_4thgenF_Body.html
Old 04-09-2012, 07:25 PM
LPE 403's Avatar
That's pretty cool!
Old 04-09-2012, 09:08 PM
stunna p's Avatar
This totally fixed my brake issue 100% I have a huge cam. The high dollar pump is not needed in my opinion. try one of these!
http://www.summitracing.com/parts/MRG-3701/
Old 04-10-2012, 03:58 AM
LPE 403's Avatar
Install pics?
Old 04-10-2012, 06:29 AM
DAVE00's Avatar
I have a canister installed and it's not helping much. I'm only pulling 12-13" vacuum at idle.
Old 04-10-2012, 06:35 AM
DAVE00's Avatar
Man I'd love to go that route as you're right it's the best option, however damn it's going to run you over $800 and I can buy 3 electric pumps for that price.
Old 04-10-2012, 03:58 PM
LPE 403's Avatar
Which elec pumps are you looking at? Have to go the "assisted" route myself. Elec pumps are a little noisy from what I've heard.
Old 04-10-2012, 07:04 PM
ZexGX's Avatar
How many new '95 T/A's, 383 Strokers, 190cc AFRs, LE Custom Cams, BBK 58mm throttle bodies, FAST 42# injectors, MSD BILLET OPTIs, and full suspension setups can you buy for $800? Braking functionality is kind of high on my priority list...
Old 04-12-2012, 05:44 AM
speed_demon24's Avatar
I only have 10" of vacuum and my brakes are amazing. If you're still running stock LT1 brakes that's your problem not the vacuum unless your legs are weak as hell.
Old 04-12-2012, 06:31 AM
DAVE00's Avatar
I'm running the older Baer 13" track kit (based on the C4 design) and it's brand new. I don't know what your talking about but everyone I've spoken to or thing I've read says that your brakes will be hard as hell if you are running weak vacuum due to your booster not working properly. I'm going to pull the MC and bleed that this weekend first and see if I have any air trapped in there first and then go from there.
Old 04-12-2012, 07:27 PM
ZexGX's Avatar
Sounds good. Let us know...
Quick Reply: Anyone running Electric Vac Pump for Brakes?
