Break Booster or Master Cylinder?
Old 04-13-2012, 09:40 PM
MAROBOY_TRAV's Avatar
Default Break Booster or Master Cylinder?
When the car is off the pedal is loose not stiff.. when I start the car and pump the breaks, the pedal will get stiff.. When I drive the car and as i come to a stop the break pedal will go down halfway an then drop down about another inch until it reaches the back wall..
Old 04-14-2012, 09:59 AM
Anyone have an idea?
Old 04-14-2012, 10:03 AM
Blu99T/A's Avatar
Sounds more like the master cyl. When the booster goes bad, it usually creates a hard pedal symptom.
I would check all your brake lines, connections and calipers for any new signs of fresh brake fluid before replacing your master cyl. though.
Quick Reply: Break Booster or Master Cylinder?
