Squeaky rear end
Squeaky rear end
Im not sure whats causing this squeak from the rearend, but in the video Im grabbing the drivers t-top and shaking the car, and it also happens when someone shuts the doors. I have a UMI adjustable torque arm, Lakewood LCAs, Bilstien shocks, Hotchkis springs and a stock panhard rod.
http://www.youtube.com/watch?v=NZeyPOOjYtU
I'd start with the sway bars. Not sure how there mounted on an f-body buy the c5 vette sways have a bushings that dry out. I wrapped my sways under the bushings with tephlon tape and no more squeeks. Hope this helps
LS1Tech Premium Sponsor
Make sure the Lakewood LCAs are greased up after that I would check the factory sway bar bushings. I would just spray some WD-40 or something similar on the bushings and see if the noise temporarly goes away and if it does that will be your culprit. I know on my 99 T/A they squeaked like crazy once they got some age to them. If it is the sway bar bushings Prothan and Energy Supsension both make factory replacements or you could do what I did and use it as a time to upgrade sway bars.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
When did u start noticing the sound? I had something similar happen to me after I installed stranos and found out it was just that rubber piece (spring isolator i think?) above the springs in the rear wasn't lined up right so their was a little metal on metal contact. Once I straightened it out, it was gone. Only mentioning since u have hotchiks springs. Hope it helps.
