need info on agx shocks
ok so i got agx adj shocks in my 01 camaro, they were on my car wen i bought it and i want to know how to adjust them. like is 8 the stiffer and 1 the softer or the other way around. Also should i have my shocks stiffer in the back? im trying to set them up for street, so my ride wont be so harsh.
When i had them on my old car, I had 5 on the front and 3 on the reads. Next time you are needing shock get better shocks. I can't believe how much better the bilsteins are over the agx's.
thanks fella's i think for street im going to set them up 3 all around, and wen i take her to the track im going 7 front and 5 rear, with my low psi mickey thomson street slicks. What do you guy's think?
In previous correspondence with KYB (I can't find the email at the moment) they mentioned the AGX's are 5% softer than stock on setting 1, setting 2 is "stock" and 3 through 8 are incremental up to 123% stiffer than "stock".
Without a damping curve from a damper dynamometer it's difficult to quantify what is "stock" and of course different cars had different dampers on them throughout the years, but this should give you a general idea of what to expect.
ramey
I've only got them on the front of my car with the stupid white gas-adjust in the rear. Fronts are set at 4 currently and may go up to 5 real soon. 3 all the way around might be, sorry, will be too soft in the front. I gotta get the adjustable rears.
rite now i got them at 5 all around, is still kinda to rough, i fell every bump on the road and my suspension has no play, so stiff that wen i pull in a steep drive way side ways so not to scrap the front end my rear well lifts up and does a three wheel motion lol, i may try 3 all the way around to see how i like it. and for track ill set them up at 7 in the front and 5 rear so i can get a good launch.
Good afternoon.
ramey
ramey
Mine's my daily as well. And the roads here in California, not exactly fun either. I won't run mine the same all the way around. You'll probably find that if you drop the rear a couple clicks lower than the front, you may find a slightly better ride.
