Lca relocation brackets???
Old 05-12-2012, 04:55 AM
lilblackLT1's Avatar
Default Lca relocation brackets???
Moser 9 inch, stock height, Spohn adj tq arm, adj lca's w/ del-sphere joints.....what holes should the lca's be in on the relocation brackets for best launch
Old 05-12-2012, 07:24 AM
SS SLP2's Avatar
most time lower is better for launch, but may cause hop at hard braking
Johnny
Old 05-14-2012, 08:22 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
If you are lowered or are looking for the best straight line performance and traction then the bottom hole will probably be your best bet. This isn't the always the case because using that bottom hole will make the power hit the tire harder and faster so if the car makes a bunch of power or is using a subpar tire it can just cause it to spin. The best thing to really do is play with the setting and see what holes in the relocation brackets work best for you, each car is a little different and will want different settings.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Quick Reply: Lca relocation brackets???
