v6 control arms vs v8 control arms?
Old 11-07-2012, 10:45 AM
1bad lad's Avatar
Default v6 control arms vs v8 control arms?
Guys i need to know if the v6 control arms are the same as v8 control arms on an fbody? can i use the v6 lower upper control arms and just swap the kmember?
Old 11-07-2012, 10:48 AM
NicB's Avatar
Yes they are the same. Springs/shocks only difference
Old 11-07-2012, 02:24 PM
SparkyJJO's Avatar
Shocks are the same (junk) too. Only difference is the springs.
Old 11-07-2012, 02:40 PM
1bad lad's Avatar
how much different are the springs. I wonder how it would sit with an ls1 with v6 springs. isnt the v6 an iron block. The 2 engines gatta be similar in weight.
Old 11-07-2012, 03:07 PM
SparkyJJO's Avatar
I don't recall. Pretty sure the V6 front spring rate is around 260 lb/in but not sure what the LS1 rate is. Rears are the same regardless of engine size.
Quick Reply: v6 control arms vs v8 control arms?
