CTSV brake upgrade
Old 12-30-2012, 02:32 PM
98silvermaro's Avatar
Default CTSV brake upgrade
Has anyone done a CTSV brake upgrade on the rear for a C5 or a Fbody???
Old 01-01-2013, 12:14 PM
anybody?
Old 01-02-2013, 04:02 PM
nothing?
Old 01-02-2013, 11:06 PM
hXc95SLS's Avatar
I have a first gen CTS-V. What do you want to know?
Old 01-03-2013, 07:02 PM
I know plenty of people have done the first gen V brake upgrade on the front of the fbody's and vette's and im trying to figure out if anyone has done it for the rear brakes
Old 01-03-2013, 09:47 PM
Empatho's Avatar
Yes it has been done before but you will get brake pad knockback with the 10 bolt.
Old 01-04-2013, 09:32 PM
what do you mean by knockback? and did they bolt right up or did they have to modify a bracket?
Old 01-04-2013, 09:39 PM
lees02WS6's Avatar
It's been discussed many times. GMHTP did an article covering what's required. The gm 10 bolts used in these cars have their axle shafts retained by c-clips. The axles float in and out slightly, the floating calipers are able to cope with the movement. The pads on a fixed caliper, on the other hand, would get "knocked" back from the movement of the axle shafts moving in and out.
Old 01-04-2013, 10:26 PM
alright well i sold my camaro not to long ago and I now own a C5 FRC so I was looking to do the upgrade on it. So everything on the vette should bolt right up and ill be to go pending on clearance from the wheels?
Old 01-04-2013, 10:30 PM
lees02WS6's Avatar
Yes on a car with an independent rear you'll be fine to do that.
Old 01-04-2013, 10:32 PM
Thank you sir... now I can price out the parts at work. thanks again everyone
Quick Reply: CTSV brake upgrade
