Break Pull???
Break Pull???
Ok problem was whenever you get on the brakes hard they pull extremely bad. So we purchased and installed new Stainless Steel brake lines ( yes all 4 were replace. Installed new slotted and cross drilled rotors, new aftermarkey pads. Guess what the problem is still there WHY?
1 Post
probably a ceased slider or caliper. I would have replaced the calipers and hardware first before the lines/pads/rotors....
How hard was it to push the piston back into the calipers?
