Master cylinder install? Help.
Old 05-19-2013, 10:20 AM
Black Sunshine/ 00SS's Avatar
Default Master cylinder install? Help.
I'm attempting to start to put my car back together. I got it back from a break in at a shop. I've noticed many loose bolts on the car. So I'm taking everything out, and putting back together.
I know the shop dropped the motor out the bottom. Of concern is that the brake cylinder is just pushed onto its mounting bolts, and will pull off if I loosen the feed lines. Since I didn't take it apart, I need to know if it simply needs to be bench bleed, and then mounted? Is there a spring that mounts between the cylinder and the booster?
A diagram would be nice. Just want to understand what I might be missing, besides the cylinder mounting bolts.
Old 05-20-2013, 09:19 AM
Can't find a diagram, but took it off, everything looks good, except for a broken sensor plug on the master cylinder. Looks like it wasn't unplugged when the k member was dropped.
Quick Reply: Master cylinder install? Help.
