Spring rate recommendation
Old 05-22-2013, 11:47 AM
spcearle's Avatar
Default Spring rate recommendation
Looking for ideas on coilover spring rates for a daily weekend warrior lt1 camaro... This is pretty much a full weight car with full options/ tubular chassis cfm hood... I do take long trips with it frequently but am installing my front chassis and co in a few months and need to get front and rear springs so any input would be welcomed from those that have experimented or use certain rates
Old 05-22-2013, 12:17 PM
Mighty Whitey's Avatar
No less than 300lb/in
Old 05-22-2013, 01:04 PM
spcearle's Avatar
How about rears
Old 05-23-2013, 02:58 AM
Are you setting it up for drag racing or autox?
Old 05-23-2013, 07:55 AM
z28bryan's Avatar
The rate usually depends on the spring length at loaded ride height. The lower the ride height, ideally you want a higher rate. Unfortunately wtih the aftermarket springs out there that are REALLY low, they don't seem to follow this guideline.
Old 05-23-2013, 11:49 AM
spcearle's Avatar
its a street car that will see some track time....deff not looking to lower it except thru the coil over adj....in fact the redneck in me tends to give the *** a lil lift for a raked look and to clear my 28's....right now i have stock fronts and eibach drags in the rear....looking for rates and length to not loose complete streetability but still be able to perform on the track some
Quick Reply: Spring rate recommendation
