brake fittings
Old 05-28-2013, 11:23 AM
Thomas Aquinas's Avatar
Default brake fittings
So I was trying to install new braided flex lines on my camaro this weekend. I was able to do half of them.
I could not get the fitting that goes from the hard line to the flex line loose for the other half.
I was using a 12 mm flare wrench, and a ton of PB blaster. I let the PB blaster soak while I did sway bars.
Any other product that might be better? Or tips?
Thanks.
Old 05-28-2013, 03:28 PM
libertyforall1776's Avatar
I am having trouble getting the three way fitting loose on the over the axle line on my RS -- going to have to soak it again -- worried I might strip the nut though.
Here's the best product, NO IT IS NOT PB Blaster, at least according to their tests!:
http://www.zzperformance.com/blog/pe...ls-compared-2/
"Penetrating Oils Compared
Machinist’s Workshop magazine actually tested penetrates for break out torque on rusted nuts. Significant results! They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a “scientifically rusted” environment.
Penetrating oil ….. Average load
None ………………… 516 pounds
WD-40 ……………… 238 pounds
PB Blaster …………..214 pounds
Liquid Wrench …… 127 pounds
Kano Kroil ………… 106 pounds
ATF-Acetone mix… 53 pounds
The ATF-Acetone mix was a “home brew” mix of 50 – 50 automatic transmission fluid and acetone.
Note the “home brew” was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now
use it with equally good results. Note also that “Liquid Wrench” is about as good as “Kroil” for about 20% of the price."
Old 05-30-2013, 10:35 AM
Yea, I found that article! I think I might try that ATF-Acetone mix. And if that doesn't work.....
Quick Reply: brake fittings
