Ware to get longer brake lines
Hey guys, I have a BMR K-member/A-arm combo and the stock break lines (rubber part) arent long enough to fit where the new tab is located which is the union of the steel tubing and the rubber part. Ive measured it a few times and it seems as if i need a 16" break line to make sure the wheel can fully turn in both directions and isnt restricted or doesnt pull the line.
Does anyone know where I can get a longer stainless steel/teflon brake line with the square ends that fit nicely to the stock caliper?
