lowering spring
Make sure you also have an adjustable panhard bar.
^ Don't post some BS about not needing an alignment.
OP. When you change the height of a car toe, caster, and camber change. Thus you need an alignment whether the tires are wearing funny or not.
LS1TECH Sponsor
I think it'll be easily possible.
__________________
LS1Tech Premium Sponsor
After lowering the car it will still drive but the alignment specs will be off which will put extra wear on the tires and shorten their life.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Giving it time to settle is also a very good idea, you just don't want to put too many miles on the car without an alignment.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
LS1TECH Sponsor
Not checking the alignment is up to you. It's silly unless you can verify for yourself everything is fine. I've heard this a million times "it's fine". Then 10k miles later the front tires are done and so on.
Before you started was the alignment known good? You then unbolted things and changed the ride height, which changes the location of pickup points on the suspension vs. the balljoints, you gain negative camber. It lowers the steering rack, but the tie-rod end to knuckle location doesn't change, that toes in the car some. Enough to cause you issues? Maybe, maybe not hugely, but it will change something.
__________________
An adjustable panhard bar is needed when lowering to adjust the rearend and keep it centered. When a car is lowered the rearend will be pushed off center to a side because of the fixed panhard bar an adjustable one is recommended to fix this.
Just finshed lowering my car kyb-shock 1.5 drop. Panhard bar lower controll arm an relocation bracket. Now the bad new need front sway bar ends. Another week shot.
