Upper control arm support?
Oh i had the same thing! mine was extremely bad, literally flaking apart when i did shocks.. i got one from a guy around here that parts camaros and the one i got was just surface rust, so it works great. Im sure you can get one at the dealer
http://www.gmpartseast.com/chevy/com...1mm61fp87.html
You cannot buy it by itself you have to buy item #8 which comes with a new upper control arm already bolted up to it with a new upper ball joint. I know because I just bought one for my camaro. I just took the control arm off and used the strut mounting plate.
So when you take the strut mount off the shock, is that the only piece that comes off? Why I ask is I bought new strut mounts and have new springs and shocks and the nuts that hold it on, if there is not then I am not going to take the stock ones apart.
