rear end?
Old 08-06-2013, 09:44 PM
sold horse,bought ss's Avatar
Default rear end?
can the rear end be swapped from a car without traction control to a car with traction control?will the traction control still work after the swap?thanks
Old 08-07-2013, 10:52 PM
dang,have I asked a question that nobody can answer?
Old 08-08-2013, 12:10 AM
garygnu's Avatar
I believe not .a rear without TC is a 3 channel rear ,a 4 channel rear is meant to work with TC .you can swap a 4 channel rear to a 3 channel car and tune it .
Old 08-09-2013, 11:45 AM
FirstYrLS1Z's Avatar
neither swap will work,you cannot 'tune' either system.
putting/installing the 4 channel axles and backing plates will make the 3 channel rear a 4 channel.
Old 08-09-2013, 12:07 PM
It's not mine! woo hoo!
demonspeed's Avatar
You just asked it in the wrong section of the forums. Here is a link to the rear/gears section: https://ls1tech.com/forums/gears-axles-15/
Old 08-10-2013, 08:30 AM
Smile
thanks bud.that's the details I need.the housing and carrier is the same but axles and backing plates are different.
Old 08-10-2013, 08:40 AM
alexus6798's Avatar
Yep, as said above take the axles, backing plates and sensors from the 4 channel rear and just swap them over into the 3 channel rear and you are set to go. Keep the 3 channel abs sensor in the top of the rear to plug the hole.
Quick Reply: rear end?
