1le sway bar kit???
1le sway bar kit???
hey guys i just came across a great deal on a new 1le sway bar kit the front is 32mm and the rear is 21mm the only down fall is alot of the original 1le parts are discontinued and i needed help finding the 21mm rear stabilizer bar insulator bushing's (GM p/n 10235886) or a p/n for a alternate set that would work since the original's are discontinued any help would be great thx
i also noticed the rear sway bar looks a little different than the one i have on the car let me know what you think
here is a copy of the link http://www.ebay.com/itm/221265983292...84.m1438.l2649
If you haven't bought then yet, then spend a little more and get the Strano sway-bar set.
http://www.stranoparts.com/partdetai...=125&ModelID=2
i was at the local performance shop today we were talking and i showed him the same pics and he said there could have been a standard 1le 21mm and maybe a different 21mm for the autocross package? this a message from the ebay seller let me know what you think
I completely understand your situation.. I purchased all of these items from two different GM dealers over 8 years ago.... I did so much research back then to make sure I had what I wanted. The rear sway bar in question (1LE Rear 21 mm Stabilizer Bar (GM p/n 10021221)) is the piece I got from GM dealer and although the tag or sticker is missing, I was told it is the 21 MM solid bar. Upon receipt, I did note that it is solid so I did not worry any further. At this point I think I should place a note in the auction that the rear bar may be a different part number since you have raised this concern.. If it is not what I was told by the dealer 8+ years ago that is a error I cant fix now.... To make if fair I will take $25.00 off the sales price should you win the auction.. I am very sorry to have the as a problem now. The other parts are correct for sure and are worth the current offering price.
