The Ultimate TA
Not cheap, you get what you pay for. I'm impressed
The issue with the short torque arms is if you really get on your brakes hard, the opposite happens causing your axle to pull up and brake hop becomes much more likely. Brake hop if bad enough can damage your rear end.
For most people on street driving, you probably won't ever use your brakes this hard, so a short tq arm is probably beneficial for certain applications.
I've got an unbalanced engineering decoupled torque arm which actually decouples under braking and allows you to stop harder than a long torque arm. I'll argue that I got the ultimate TA
We worked with GM High Tech Magazine on project "STI Killer" and were able to get it to handle amazingly well with BMR Suspension components. For the torque arm we used our full length adjustable torque arm along with our torque arm relocation crossmember. This setup allows you to not only adjust the pinion angle but also the instant center of the car so you can fine tune it to get the handling and the feel you are looking for.
BMR full length adjustable torque arm (TA001)
BMR T56 torque arm relocation crossmember (TCC006)
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
i so want to pull the trigger on this TA...i'd like to hear your thoughts Bryan.
I don't know if I'd say extacy. I am launching a lot better on it and feel much more confident on corner exit.
I'm only one opinion. Frrax has alot more.. there's a lot of people there who own one and have a lot of experience with it.
Once you get it in, it appears to be common for most people to make 1-2 adjustments to the preload on the brake link. Once it's set... forget about it. It's good to go. I think I need another half inch of a spacer in my brake link and then test it out at another autox.
