strano settlement.
Old 09-30-2013, 02:41 PM
GHall8788's Avatar
Exclamation strano settlement.
I recently had stranos installed with stock shocks, drove for about 15 miles then had the car jacked up to work on calipers, the drivers side was jacked up all through the night where the other wasn't, now the car sits lower on the passenger side. this was about a week ago. Will it eventually settle back?
Old 09-30-2013, 02:53 PM
therealcreeper's Avatar
These cars almost always sit lower on the passenger side to begin with, you just don't notice because there's so much wheel gap. It could have nothing to do with the springs.
Old 09-30-2013, 03:21 PM
GHall8788's Avatar
Oh ok i did not know that. Do you think adjustable shocks would fix it?
Old 09-30-2013, 05:02 PM
fruitsalad's Avatar
I don't have Stranos but I am lowered on stock shocks. When I jack mine up and it sits weird like that, I go over to the side/corner that's sitting up too high and give it a good push down and that usually takes care of it.
Might sound kind of stupid and I don't know if you tried that already but maybe it would help.
Edit: I re-read and realized you're talking about brand new springs. They will most likely settle over the course of a couple weeks.
Old 09-30-2013, 08:28 PM
Shocks have nothing to do with ride height, except in the case of having an alternate perch
Old 10-01-2013, 07:10 AM
Save the manuals!
wssix99's Avatar
This is a normal thing and Sam Strano also comments in this thread: https://ls1tech.com/forums/suspensio...-one-side.html
Old 10-01-2013, 11:23 AM
LS1TECH Sponsor
Sam Strano's Avatar
It's about 1/2" higher on the left than the right, regardless of springs used. It's how the car is designed.... it will always have a driver in it which lowers the left when you drive down the road. If you don't believe me, try swapping rear springs side to side, it won't change.
You just notice it more when the car is lowered because the wheel gaps are smaller.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 10-01-2013, 04:29 PM
GHall8788's Avatar
Awesome, thanks for the help guys!
Quick Reply: strano settlement.
