Stuck rotor
Old 10-06-2013, 04:49 PM
lookin4aTA's Avatar
Default Stuck rotor
Trying to change the pads and rotors on my '99 and I can't get my left rear rotor off. It doesn't seem like it is stuck on the studs, but I cannot see all the way inside to check. I have tried beating the hell out of it with a rubber mallet and that hasn't worked yet either. Thoughts?
Old 10-06-2013, 05:11 PM
nicksuli's Avatar
Maybe something wrong with the Parking Brake? It could be holding it on the axle.
Old 10-06-2013, 06:14 PM
lookin4aTA's Avatar
Yeah there was an issue with the parking brake..............I never disengaged it. Now to figure out how to get the caliper back on the rotor. I am having a hell of a time getting the piston compressed on this one.
Old 10-06-2013, 10:06 PM
99Bluz28's Avatar
Use a large C-clamp and one of the old brake pads to compress the piston.
Old 10-06-2013, 10:08 PM
SparkyJJO's Avatar
Originally Posted by 99Bluz28
Use a C-clamp and one of the old brake pads to compress the piston.
And crack open the bleeder to relieve the pressure. Makes it a LOT easier. I can usually press the pistons back in with my thumbs when I've cracked the bleeder open.
Old 10-07-2013, 12:31 AM
lookin4aTA's Avatar
Ah! Maybe that was the problem. The front was fine but the rear has been a bitch to get done. Where is the bleeder on these things? Haven't changed brakes in years, and never on an F-body.
Old 10-07-2013, 12:32 AM
lookin4aTA's Avatar
Got the C-clamp and I was still having a hard time with the rears. Now just need to find the bleeder and go from there.
Old 10-07-2013, 07:45 AM
SparkyJJO's Avatar
It is right on the caliper... have you never used them before?
Old 10-07-2013, 11:46 PM
Copy & Paste Moderator
VIP1's Avatar
Just remember that if you do loosen the bleeder, you will have to bleed the brakes.
Its the small bolt with a nipple/hole on it at the top edge of the caliper.
Also, brake fluid is corrosive so don't let any touch paint.
Old 10-08-2013, 11:56 AM
mab6680's Avatar
you know if you cant get the pistons in with a c clamp most likely there something wrong with the caliper.
Quick Reply: Stuck rotor
