wheel hop front suspension
i have a 95 camaro lt1.
I recently installed new Beiltein shocks or struts on the rear and front. about 1yr ago.
The rear ones are fine with no hops. Installed rear and front on the same day.
the front passenger side is the major issue with the wheel hops and it did this since day one with the new shocks.
I have the following suspension mods. Which were installed 7 months after the shocks and struts. The wheel hop occurred after installing the new front shocks or struts. I double checked how i installed them and its weird the front passenger is the only only one that does it.
Rear UMI LCA's, UMI STB, UMI Panhard Bar, UMI Sway bar kit(F&R) w/new links, UMI Subframe Connectors.
Maybe i need an alignment? The K-Member and upper parts are stock. like a-arms etc.
Last edited by davidc212k; 12-03-2013 at 08:49 AM. Reason: forgot something to add
Location: Land of the Mormon's although I'm not one of them
What do you mean by hop?
Normally suspension "hopping" occurs in the rear wheels when they break traction and the shock/spring combo can't settle the wheel motion, so it "hops" up and down.
What exactly is happening on the front?
Im going to take a better look at this again. il try and take a few pics or even video. in case im doing something wrong.
