Left front wheel movement.
Old 01-09-2014, 09:36 AM
SlasherVRGR's Avatar
OK, I've done some searching and cant seem to find an answer for this.
What is worn out or broken that's causing a clunk when i come to a stop or take off in the left front?
It also seems to move the wheel slightly forward or backward when this happens.
Its been extremely cold so i haven't really had a chance to poke around under the car yet.
Thanks in advance for any help!
Edit: Car is a 98 Camaro
Old 01-09-2014, 04:06 PM
joecar's Avatar
Worn out lower control arm bushings.
Old 01-09-2014, 04:21 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
This would be my best guess also. Check out the lower a-arm bushings on your vehicle and let us know what kind of condition they are in.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 01-10-2014, 09:19 AM
That was my assumption also, the LCA is def tweaked a tad as well. It was in an accident before i bought it.
Ill just leave it sit till all the snow and slush go away and then take a look.
Since i probly need an A arm or LCA or whatever ya wanna call it, would anyone suggest using tubulars?
Old 01-10-2014, 09:43 AM
BMR Sales2's Avatar
Replacing your factory lower a-arms with tubular lower a-arms definitely wouldn't be a bad idea since you will need to replace the bushings in your factory ones any ways. The nice thing is that if you go with the tubular lower a-arms you will save a little weight but they will come with new bushings in ball joints so it will make your life a little easier. We have our regular BMR lower a-arms (AA002) and our 1" lowering lower a-arms (AA020) so it gives you an option depending on what you are wanting to do with the car.
BMR 1" lowering lower a-arms (AA020)
__________________
Glenn ***
Sales Tech
813.986.9302
Old 01-10-2014, 01:23 PM
garygnu's Avatar
check all the ball joints and bushings ! and check your shock mounts . replace both sides .don't put it off ,it could be costly .
Quick Reply: Left front wheel movement.
