Front Sway Bar Mounting Clamp Bolt Size and Bracket - 1995 Camaro
I am installing a BMR front sway bar on a 95 Camaro. The original was removed by the previous owner. I am looking for the size of bolt that holds the bushing bracket. Also, on the driver side below the bracket there is another bracket (bolted on from the right side) that overlaps the front bolt hole of the bracket. Can you tell me what this other bolt hole is for? It is about 1/2 inch below the hole and interferes with putting the bolt in place.
