Brakes wtf!!!!
Brakes wtf!!!!
I'm bout to burn this birch to the ground...
New rotors
New bench bleed master
Sjm abs delete
Calipers are installed correctly
Brake hoses are not faulty
STILL SPONGY AFTER POWER BLEEDING
Old school bleeding
Vacume bleeding.
I don't get it!!!!
New rotors
Sjm abs delete
Old school bleeding
Vacume bleeding.
I don't get it!!!!
The caliper needs to slide to apply the out board pad, if one or both of the slides are frozen the caliper will twist/flex under pressure, when the pedal is released it will unwind leaving an air gap.
were did u get the master from,what auto store. I went through 4 of them at one time. you get what u pay for. the rebuilt ones never last or work. just buy a new one. I have had problems with autozone,orilley and advance. i used napa and they work great.
