Need help with BMR lower A arms
Old 06-16-2014, 11:32 AM
Z28Dave's Avatar
Default Need help with BMR lower A arms
Alright so I'm assembling my BMR K member to the lowers but I cannot get the outer rod end to spin to have the correct angle or lenght to set it in the k member. The other side spun just fine thought the other is giving me a hard time, it's almost as if has seized up or was cross threaded. The locking nut is loose and away from the A arm. I don't want to snap the rod end but it turns very slowly when applying extreme pressure. So far I have it soaked in PB blaster to hopefully loosen it up.
Has this happened to anyone? Any possible remedies?
Old 06-16-2014, 02:32 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
How old is the arm? When these are originally assembled the threads receive a generous coating of anti-seize lubricant. Can you un-thread the end from the end and get a picture of the condition of the threads on the rod end and the inside of the arm? It is possible to run a tap in the arm and a die over the rod end to clean up the threads.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 07-19-2014, 05:51 PM
Z28Dave's Avatar
Sorry for the late reply but I can't unthread it as the rod end is stuck in the A arm. The part is maybe 3 months if that, the other side I can unscrew with ease and tight down. The other side seems to be stuck and will not turn no matter what I do. This is the only part that's holding me back from assembling my car back together and it's a real pain .
Old 07-19-2014, 05:54 PM
Z28Dave's Avatar
The Rod end is stuck and has been for a while.
Old 07-21-2014, 10:26 AM
BMR Tech2's Avatar
Was it able to be moved when you first got the arms? Either way, give me a call here and I will get you taken care of with a replacement. Something is definitely wrong there
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: Need help with BMR lower A arms
