Bmr driveshaft loop question
Old 06-21-2014, 09:31 AM
Double J's Avatar
Default Bmr driveshaft loop question
Hi, purchased a used one on parts classfied here, I discovered i don't have a cross member support or the bolts to use to install loop. My question: what are the correct size, length & thread size? So i can purchase at Home depot? I emailed BMR Tech support but got no reply. Thanks in advance.
Old 06-22-2014, 08:13 AM
Double J's Avatar
Bump for today
Old 06-22-2014, 03:37 PM
Super Hulk Smash
JakeFusion's Avatar
M8-1.25. 25 or 30mm length.
Just goto Lowes and find a body bolt, which is a Grade 8.8 bolt/washer combo that is M8 (and it only comes in 1.25, which is the coarse thread and the correct one for the car) and is 30mm or 25mm long (can't remember). The larger washer is what you want for the DSL as it is elongated to allow for adjustment, but that means you need more washer than a standard M8 washer. I also wouldn't trust a fender washer there as I couldn't find any 8.8 or better washers.
Old 06-23-2014, 09:07 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
When did you e-mail us? But JakeFusion is right. If you have too much trouble finding the hardware you need locally, give us a call and I will get you setup
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Quick Reply: Bmr driveshaft loop question
