Help Adj. Panhard Rod!!!!
So the grease fittings are supposed to be on the bottom, well i isnstall the fixed end first....w/ the fitting down so its easy to grease, and then go to the adj. side, well i'm off a little, my car is lowered an inch or so, my problem is the measurement from the outside of the wheel well is 1 and 3/4 incfh on the pass. side and the driver side its less than a 1 and a 1/4, my question is, how the hell do i fix that? i know i obviously need to "adj" the panhard bar but then how the hell do i get the wholes to line up for the bolts?? HELP Quick needed, car is needed in the a.m. thanks all!
Originally Posted by Silly02SS
you should be able to put the bolts on and then adjust the bar with it bolted on
I set mine to the stk length and them turned my rod end out or in a turn depending on which way the axle needed moved. Mine was sitting towards the drivers side.
Originally Posted by 2w0s060
If it has a poly end it probably isnt "on car" adjustable.
Originally Posted by 99CamaroSS
Right but how once you turn it, it doesnt line up w/ the mounting holes...so how do you move the axle so that the holes line up??
